CMF_Markie
» CMF Member
what can i do to my car to make it faster other than extracters and exhaust? and where can i get it from? or is it better to do an engine conversion?
CMF_Greo
» CMF Member
Injectors, upgraded throttle body, strip out some of the heavier items in your car & swapping to higher compression pistons should help too.
For a large improvement the turbo/super charge is your best option.
CMF_knotan
» CMF Member
the original camshaft is designed for cheap fueleconomy .
a planed head for higher compression combined with a better camshaft should be the most cost-effecitve way to get a few more hps. that is if you dont want to turboe it...
CMF_Greo
» CMF Member
nsm on this site sells extractors (I think.)
and exhaust will depend on where you are in Australia really.
You are down near Coffs Harbour so I cant suggest anyone, but a local mechanics may know of a good exhaust work shop. or someone on here might.
you probably want to look at 2" diameter piping for the exhaust
