ecu question
after racing yesterday (1.3), my main rival was a colt (1.3), i could beat him on the straights but in the coners I would lose grip and he would pull away a bit more every lap, im going to lower and stiffen up the suspension, but some people were saying that if I put in a 1.3 ecu instead of the 1.0ecu it will fuel better around the coners, is this the case or would changing the ecu make much of a differnece.?
also if doing the ga16 T/B and injecters change will the ecu need remapping or would the 1.0 or 1.3 ecu handle it.? and does anything else need changing at the same time.?
You have handeling issues not power if you can pull away on the straights.
If you change anything like TB/INJ the ecu won't have a clue what's going on and it will need reprogramming.
Contact me if you want more info about going down this route :)
