hey everyone, soz for the lack of updates cos I've been real busy at work and not much done to car as i'm just tryin to enjoy it.
Back at end of May, some of you may have read bout Sulur who needed to replace his damaged engine, so i drove down there with the spare cg13de from me garage, helped install it but in the end it didn't work out. neway we packed everything up and i was about to drive him to a nearby ATM to refund him. went into reverse and moved a metre backwards out the driveway when all of a sudden something went BANG!! the car lurched & rocked back, stalled, gearstick stuck and the clutch pedal dropped to the floor
What the Heck!? this was the last thing i needed while i was exhausted, had to drive home 180miles away for work the next day.
opened bonnet and saw the clutch bracket had sheared away from the clutch arm due to a broken pin. when the pin broke during mid-engagement, the clutch arm had sprung back so hard that it was jammed up. i couldn't move the arm back enough to reach the cable. oh bumma.
while almost panicing from the thought of having to maybe split open the engine/gearbox to fix the clutch, i looked up a pic of the clutch mechanism on me laptop to see what could be jamming and if the thrust bearing bracket could've seperated from the arm. i jiggled the arm up/down/sideways until eventually i could return it back to reach the cable.
but now the brackets missing the pin so i stuck an allen key though the hole, hook it up to the arm and test if the clutch still works and it felt normal. obviously i couldn't drive home like that so asked sulur if i could use the bracket from his SR that was parked with my spare smoking engine. installed and managed to get home, cautious bout the bracket breaking again.
here's the clutch bracket with the riveted pin sheared off
new clutch bracket with broken pin vs Sulurs used bracket that got me home
now the shiney new clutch bracket was installed just few months ago so why the heck has it failed? manufacture defect? or poor design? before the failure, the pedal did feel stiff and squeaky earlier that day.
here's the bush on the rivet pin thats worn from years of operation. i don't feel the pin is made secure enough so i'll replace it with a nut/bolt
drilled the hole in the broken bracket to 6mm and screwed on a threaded bar & nut to beef it up
hooked up and installed. hopefully this never happens again.
View attachment 15786View attachment 15785
yesterday a relative called me about doin a trackday at Rockingham in August 10th
i always wanted to take my car for a blast down the track and after talking to him for ages discussing about the whole thing we agreed on booking the session in advance next week.
website says £179 per car/person but more ppl per booking = discount down to £150
would be awsome if summore micras could join
i'll need to swap back over the original GTIR brake discs so i could get the grooved disc lip machined down by 3mm so it doesn't rub the calipers during the intense track braking.
He also recommended i upgrade my pads from mintex mdb1920 to either Ferodo ds2500 track pads or some Black Diamond Predator Fast Track pads as i'll need all the braking stamina i could get from a fast track.
i found some black diamond FT and EBC Yellowstuff in essex and Ferodo ds2500 on ebay
http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=519797
http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=3936345
http://cgi.ebay.co.uk/NISSAN-SUNNY-Mk-III-Hatchback-2-0-GTI-16V-FERODO-Front-/190401449177
anyone used or recommend any for mainly daily commute and occasional track use?
less dust would be nice for these white rims but good cold bite when commuting and high temp fade resistance when on track is more important.
maybe i should use the mintex for daily commutes then swap to high temp trackday pads when i'm at the track?
