If your vehicle is dry on inside, you don't need that...!This is what I'm trying.
It's applied to the inside of the windows.![]()
Rain-X Anti-Fog 200ml | Halfords UK
Shop the latest The RainX Anti-Fog prevents interior fogging before the problem begins. at Halfords UKwww.halfords.com
Yep. Thanks for the tip. I'd already bought it so I'm going for both.If your vehicle is dry on inside, you don't need that...!
Try DRY newspapers for few days...?
I would never have thought of that.I have the same problem and for me what has worked in the past is cat litter inside a couple of old socks they must not have holes in them or the cat litter falls out.
This is a good option for obsorbing moisture from in the cabin it lasted a whole year and isn't too much trouble to make.
I usually pop it on the dash at night. Ready to make a new one as each night when I return the whole car was misted last week.
Tonight the front screen is misted so it needs doing tonight.
The other thing that helps is avoid liquids in the cabin bottles cannot hold liquids 100% and this tiny amount of loss can cause mist.
No we've not had a frost yet. Need one soon for my Xmas parsnips !! The Micra actually belongs to my daughter. I've bought a half cover for the frosty days. Hopefully that'll save a fair amount of time on cold mornings.I just re done mine now cause I'm facing west (due to working on rear) The best way is to face ur car into the sun rise this helps as well because the sun can do some of the work for you when the screen freezes might also help with misting.
It hasn't frozen yet this year that I've seen tho.
Here in the Land of the Finns at winter time quite many people use electric engine heaters, installed to coolant plug on engine blocks to warm up coolant at freezing temperatures and interior heaters, no window ice scraping needed...
Defa-lohkolämmitin #411360 Nissan 45-9360
Defa Termini II 1400 sisätilanlämmitin 1400 W Termini-pistoke (#430055) 45-50ount of snow brings our area to a virtual standstill.![]()
I have visited the UK several times. I'm aware of the weather situation in your country.Even moderate amounts of snow bring our country to a virtual standstill. We are just not geared up for it. I guess it's difficult to justify given the number of times we see snow.
