delay in power
Hi, just got my micra 1.3 back on the road after about 10mouths off the road it fills like it has a delay in power put your foot down and take a min to pick up any ideas?
How would you suggest cleaning it? It looks like something you're best not touching to me.
Perhaps he has a mouse nesting in his airbox feed
To clean the MAF, remove the airbox and squirt some carb cleaner from a distance down the throttle body onto the sensor.
right cleaned the throttle body seems much better but got another problem now when cold it revs to 2500 rpm then down to about 1500 and up again when wormed up it sits at 1100 any ideas?
hmm, they have 2 very sensitive MAF sensors inside the venturi fwn its not something i would do personally, but i,ve seen it advised a few times tho
