Crank chain sprocket
After having purchased a timing chain kit for a cg13, I went through all of the bits comparing them to the parts I've pulled off. My concern is the crank chain sprocket doesn't match, and i am worrying that the timing is going to be off. Just wanted to get a second opinion before I buy another part. Any input appreciated, thanks
Sent from my ONEPLUS A5000 using Micra Sports Club mobile app
i would check the overall quality of the kit personally, hardness check with a file etc, then refit the old sprockets if in doubt
i tried a few different settings with slotted sprockets seb, and found that it pulled stronger with some advance, with the lobes pointing like this at tdc
That's interesting, I'll definitely keep that in mind when reassembling thanks. I'll have to see how they line up with the chains back on. Are the slotted sprockets something you engineered yourself? If you have a write up I'd be keen to have a read.
