Corsa piston build with throttle bodies
What you thought no about tension in second video? Would I need the half link
chains need to be tight mate, else you get spark scatter and cam noises at low rpm
half a link will probably be too tight with new chains (i only ever used partworn stuff)
I have a 60K upper chain, lower chain and idler sprocket sitting around here if you need them for experimentation purposes :)
Haha, I've just bought a brand new chain kit for it
Oh well, il have a play with it
Guess il have to see what it's like once I've fitted it, as I don't really know what metal has been shaved of and where
My inlet stuff won't fit a k11, unless I cut this section
As I dint have a k11 to inspect, am I ok cutting and welding this part, what's behind it?
Finding a k10 that ain't silly money now would be easier
Hmmm, possibly I guess
Would it just be a case of raising up the rear mount? (Remove the front too)
Might be worth a shot then
Got my eye on one last reasonably priced k10, if it goes to much....il just pick up a cheap k11 and crack on
Got my half link on, I've removed the top left guide, and the chain fits nicely
Should I leave it like this?
Looks ok to me, the tensioner is all the way in at the moment, and can only see it pushing the chain further away from the old guide bolt hole
Can you take engine out with gearbox left in place? Can't remember
Just building up rest of the engine, swapping over bits from this cg10, lighter crank pulley and lightened flywheel
Flywheel differences
Just need few spare hours to put it all in
Got the engine back in, I'm gunna need to raise the rear mount a bit to pivot it enough to clear the itbs from the firewall, and I'm gunna have to do something about the mount/crossmember bar thing......coz the exhaust i made lives in its place now lol
Eeeerrrr, why does the engine look on the piss......
to keep the diff low and shafts straight i guess mate, and just cut the support bar away and fit through-bolts eh
So just cut it here?
Don't I need it to hold onto the front of the car?
i would cut it at the front neil, like a z shape in 1" x 2" box, with 2 bolts redrilled in the cross member and penny washers ontop
Went to put the bar back on......and the captive nut has broken off!!! What do I do !
Dam!!!!
cut a letterbox flap in the floor neil ? i usually drive a spike up the hole and through the floor to locate where to cut the flap
A better option is to fit one of these (Rivnut),. What size is the bolt, M8, M10?
You can fit them without special tools like this:-
Cool,
Got most of it back in today
Had to mount the itbs the other way round, don't look as nice, but loads more clearance
And been having a play with the actuator and where to place it, originally it was all gel together inside the bike air box
Quick question aboiut the actuator motor, all you do is put power on and it moves, then stops itself, then reverse the poles, and goes the other way then stops
.......what's limiting its movement? Only wondering because I need to think of a way to operate it, and don't want to burn it out by keeping constant power to it if it's not meant to have it......if that makes sense
They are, but I've taken the motor out, and converted it to just cable for now
I was thinking maybe once it's all running, figure out the fly by wire throttle
On the bike, the cable pulls the tps on the itbs, sends signal to the ecu, then powers the motor
.....so shouldt be to hard to make something to do that
...is it worth it though, I don't really know the benefits of having it fly by wire, (can anyone explain)
but thought it'll be something cool to play/figure out
