Collects the st today-Savage!
Baz
Cars mint,few bits of rust here and there but nothing major.
Engine is perfect although had to replace a few perish vacuum pipes
Drives like a little go kart with the nismo shocks in it.A few people laughed at me in it earlier at the lights and I just waved and laughed back at them,eat my dust!
Question for Ed :
Was told there's a nismo fuel pump in it,but it seems to whining it head off constantly and the fuel gauge does'nt work
Got the timer fitted in 10 mins and there was a harness in the car
To check the fuel pump you have to take the tank off. You may also have to do this to check the sender unit. Although, it can be tested in place, same way as any other car.
Ed
Thanks mate what sort of uprated pump will I get if it needs to be replaced because the noise is loud enough?
My uprated pump is noisy too, It shouldn't be a concern, unless it sounds like bearing failure which is very unlikely.
Is it like a constant electronic motor whining noise ?
Just took it down a back road I know like the back of my hand and the handling is class.Brings back memories of the other green St
