clutch question please.....
will a ga16 uprated clutch fit a cg10, i know that they fit a cg13... could anyone be kind enough to clarify this issue please, regards
Micka(Y)
it is a 1996 micra 1.0l lol...
ok instead of going for the light weight flywheel because i cannot afford it, will i be able to use a normal ga16 flywheel to fit the ga16 uprated clutch to my 1.0l?
thank you, appreciated
Micka
no micka, your g/box input spline is too small
ok, so its out of the question then? Or is there a frank ''special'' type of modification to make it fit?
will i need to fit a 1.3 gearbox (i have heard the 1.0l gearboxes are stronger than the 1.3 ones?).
the ga f/w will bolt to any cg engine mart, but the pcd for the pressure plate bolts is bigger (for the bigger 190mm 1.6 friction plate)
and the 1.6 clutch has the bigger centre spline, like the bigger cg 1.3/late 1.0 g/box :grinning:
All 1.3 G/B are the same, just the 1.0 boxes are different, post 98 ones are the same as 1.3 but with smaller ratios...
BTW, that Fidenza flywheel and XTD clutch are mine now... :p
