Clutch adjustment
Hi there
Im new here ;)
Have a K11 1.0 from 2003
Just had a brand new clutch and cable in the car .... a freind made it for me .....
Strange thing is that the adjustmunt screw on the cable (finger screw in plastic) is turned all way in at the threads on the cable . So its not possible to tighten the the cable more up for adjusting the clutch cable to activate the arm and clutch more which is needed when the new clutch gradually worns !
I have adjusted the height of the pedal and the freeplay correctly
The new cable should be the same as the old one
What seems to be the problem here ?
Wrong cable ?
Regs
