Anything is possible provided your pockets are deep enough.Yeah well I removed a intercooler from a subaru and i saw the tt setup and was wondering id the same can be used or sorta used. With a cut off valve and everything.
Well im not to sure im new to the whole turbo game but both came off the subaru legacy. VF27 and i think TDO4 IHI turbos. Hense why im here asking for help hahabi-turbo arno ? or compound ?
Mmm ok sounds like a plan. But in regards to engine manigement what would you suggest ? If i take the throtlebody and injectors + rail. Would i use the primere ecu? Will it fit ? Or what other options are availablethey are big turbo,s for a 1.0 engine ! my original TD04 (16g iirc) would muster about 10psi on the CG13 and the TD05 about 7 psi (both at full chat)
and i tried the TD04 on a CG10 for a while, but i had to rev the nuts off it to get any boost
my advice would be to go for something smaller personally, and smaller still if you want to bi-turbo it![]()
1992.what year k11 mate ?
there will be some info on the nistune site for those early ecu,s1992.
Ok what would you suggest i upgarde engine wise ?there will be some info on the nistune site for those early ecu,s
You reccon i can get 2 on there haha ?for twin or bi-turbo ideas, look at suzuki cappucinos. their engine is a 770cc turbo.
Not the best metal to rust ratio eitherno doubt! but cappucinos are still pretty expensive...
Haha thans for the reply guysno doubt! but cappucinos are still pretty expensive...
