M
mankian
Guest
Does anyone know how much it'd cost to get the above (CG10DE replaced for a CA13DE) done? including the actual engine, fitting, and anything else thats needed (such as gearbox)?
cheers
cheers
ricardo_swarez said:what is the ca13de? is it an automatic version of the cg13de?
mankian said:The facelift 1.3 isnt a CG13DE, its a different engine thats nearly 1.4Litre, i thought it was CA13DE but i have no idea. Could be GA14DE? :S But in general are engine transplants expensive if you get somebody else to fit it?
thanks v. much!
mankian said:i will check my handbook when i get a minute, im sure it says in there somewhere, but is it an expensive thing to do in general? thanks![]()
thanks v. much!
rlees85 said:Jim, make sure you post back here when you've done it!!!
