brake lines
mullet
mot is up at the end of the month and i had a look under the car a fait few things need sorted
for a start the brakelines are quite badley corroded does anyone know where you can buy new ones
also the sills need rewelded but thats not a problem
cheers
mullet
He'll be talking about the solid brake pipes, when mine failed for that the garage ended up doing it cause i needed the car back, they usually make them at the garage so a motorfactor might make one up.
how bad is it? is it just surface corrosion? if so just wire brush it then paint them, obviously if there almost rusted through they need changing but if its just surface then you will be ok.
