bleed brake
I made a reverse bleeding kit once when I had my series 3 Land Rover which are a right two-hat to bleed. It was a wooden frame think with a clutch master cylinder and some hose etc To be honest, a Gunson Easibleed would be best bet. I bought one recently when I was fitting my stainless hoses and it worked a treat :).
It should do, I let my spare down to 15 PSI with the Easibleed and it worked spot on :).
How do you get an Easi-bleed to fit a Micra?
We have one, with all the adaptors. None of them fit so we bought a 'universal' adaptor directly from Gunson. That didnt work either! :(
the most novel idea ive seen is a piece of tube 6mm diameter whatever fits the nipple, long enough to go into a jar, the open end of the tube is blocked up and a slit is cut up the pipe 10-15mm long with a sharp blade. works surprisingly well, need fairly thick walled tube tho.
I've before just worked the brake till it was hard then wedged in a piece of wood to keep the pedal down and quickly ran around to the brake...took ages haha but worked and its free.
But i guess a brake fluid cap, an old tyre or similar valve, suitable sized hose, some adhesive and compressed air (tyre, bike pump etc) should do the job.
Or of course buy a tool...
and for my k10, i got a spare filler cap, fit an air line connector to it, then fed low pressure brake fluid in that way and just undid the brake calliper nipples one at a time till it was running clear to change the fluid.
Ive got one of those now, cost a £1 or so iirc.
aint buying nuthing FTW :grinning:,,,,,,,,,,,,,,,,,,,,,,,,i'ma try that their above,,,,,,valving up to a infalted tyre or sumit :grinning:
mmm Ok ignore the above, the page seemed to refresh and post that itself while i was writing (dunno what to tell ya lol)...what i was gonna say was nothing to loose trying it.
