Another Set of Focals - 2 Way Coaxials
B
Ben
Guest
Got these for sale, come out the back of the focus, these had a brilliant sound to them, really easy to wire in, straight forwrd. Again wont come with any instructions or box but simple enough. If noone takes they will be going on the by along with the other set. They are Focal 130-HC model and these are the details, the RRP is around £120 and im only after £40 + P&P. Listen to serious offers cheers:
Focal 130 HC Polyflex 2-Way Coaxial Kit
Polyflex 130 HC
2-way coaxial kit
Woofer 130 HC
130mm (5-1/8) woofer,
bi-amp option,
30mm (1-1/4) v.coil,
72mm (2-7/8) magnet
Midrange -
Tweeter 25mm soft dome tweeter
Crossover integrated crossover (5kHz)
Max. power handling 100W
Nom. power handling 50W
Sensitivity (2.8V / 1m) 91dB
Frequency response 65Hz -20kHz
Fs 87.0Hz
Re 2.8 ohms
Qes 1.02
Qms 7.28
Qts 0.89
Dia 10.5cm
Mms 7.2g
Lvc 0.27mH
Hbob 12mm
Hgap 4mm
Xmax 4mm
Sd 86.6cm2
Vas 4.9l
BL 3.3N/A
Folding diameter 115mm
Mounting depth 60mm
ill do both sets at £80 delivered if anyones interested, thats some saving
also now on the bay:
http://cgi.ebay.co.uk/ws/eBayISAPI....70034729344&rd=1&sspagename=STRK:MESE:IT&rd=1
Similar threads
