CMF_doug
» CMF Member
Hi all a newbie here seeking some of your knowledge, it concerns 100/55w headlight bulbs which i fitted but found to be no use, spread of light was not as good as the standard at all niether was distance, do i need to alter/update anything to get the benefits of these bulbs.. thanks
CMF_Yom
» CMF Member
You probably need to setup an aftermarket wiring loom that uses the standard loom to act as the switching device to utilise the full 100w of the bulbs.
Secondly you may find your headlight alignment could be out and if you buy a quality bulb your light quality will be a whole lot better.
