1.3 sr clocks 1.0
I wonder if u could help I have a 1996 1.0 micra an im wanting to put in 1.3 sr speedo clocks in
would this be ok or is the calibration going to be different? ie will the speedo show the correct speed?
I read somewhere its different anybody know?
thanks
Ive only ever fitted sr clocks into 1.3s so dont know if that will cause you an issue but theyve all been plug and play.
no jst wonder if they will be calibrated the same as 1.3 ie will they show the correct speed when fitted to a 1.o?
I read an old post from 2005 that reconed there be a 5mph difference.so wanted check if this is true before I buy them!
No the speedo drive, mechanically there is no differences between the clocks.
I had super s clocks in my 1.0 gx and never noticed any errors but back then I wasn't looking for them
