WTB A/C Hose for 96 Micra K11 SLK Hatch
CMF_Brittle Back
I am looking for a replacement air conditioning hose that my local Enzed apprentice butchered and made unuseable.
I have attached a picture of a Micra with the hose highlighted that I require (red arrow).
These micras had three distinct A/C sysems installed the hose I'm on the hunt for is as per picture and following description:
The hose attaches to the compressor body (on the lower drivers side) via an aluminium yoke held in place by an allen head bolt which then has a flexible crimped hose attached which rises vertically enclosed in an expanded heat shield then travels across toward the passenger side of the radiator between the radiator and the engine where it is crimped onto the aluminium tube which continues on and bends around the upper passenger side of the radiator to connect to the condenser in front of the radiator at the front of the vehicle (on the passenger side front).
Thank you for looking (Better if you have one, even better if your prepared to part with it).
Brittle Back
Forgot to leave my email address on original posting:
mandoes@gmail.com
