would....
think its called cams lol the bit that makes ya pistons move up and down me mate has some nismo ones so was gona put them in if they fit
if you can get what ever it is and you can proove that it is genuine nismo then get it and sell it here, but with the 1.4 engine already you are at the highest spec, only things that might make a difference is different gearboxes... your engine is the best one, tune it rather than swap parts.
To backup James's thoughts, im pretty sure Tomei cams are rated for 1.0, 1.3 and 1.4 engines...so id expect Nismo cams to have the same suitability, though id advise checking aswell as making sure they are indeed Nismo.
Write your reply...
