Normal
Ok my opinon:DO NOT DO IT. 195/45/15 is the VERY most you can do. Even then you WILL need rear arch work as it WILL scrape, not only that even with the work it may scrape from time to time. 205s are whole cm wider and higher profile. You will be in big trouble trying to get these on. Its not the fronts that is the problem its the rears.
Ok my opinon:
