CMF_shalon
» CMF Memberwats the difference between a micra throttle body and a sr20 throttle body besides the electrical fitting since its a direct fit
fred WROTE:
"not a direct fit.... and no afm..need an adapter and additional afm. you mean ga15 throttle body... micra tb diameter is about 43mm ga15 is about 50mm sr20 is about 60mm.... make sure you have larger injectors to cope with the increase in air and you may need a fuel mapping 'piggy back' ecu to be sure your fuel/air ratio is ok.
turbo march-rolling shell WROTE:
"mine or gtrholics or mickeybbb's didn't run lean. even with the tomei/nismo cams mine runs spot on.. with full exhaust, cai, and extractors
sportsclassic WROTE:
"turbo march-rolling shell WROTE:<BR><BR>"mine or gtrholics or mickeybbb's didn't run lean. even with the tomei/nismo cams mine runs spot on.. with full exhaust, cai, and extractors"</DIV><BR><BR>Mine ran lean with the intake and exhaust, but every setup is different.. and every AFR gauge is different to
fred WROTE:
"i run a injector cleaner every 5000k or so...
fred WROTE:
"I thought you'd be doing some whizz bang stuff... can any injector place do that?
nz_aj WROTE:
"Does that service mentioned use an ultrasonic bath for cleaning, or just solvents?
