Replacing the Pulleys in the CVT 2012 micra 1.2 hr12de
Hi All,
The micra from hell is still giving me pain.. I bit the bullet and ordered a complete cvt rebuild kit with refurb pulleys and new belt. I will post a video of it soon as there is not much on line about it. however im still having an issue. while the car is now drivable. if I dont drive it hard the car runs fine. if I try to floor it; it works then next thing will happen is it will go hay wire and either the accelerate will not respond or the car will slow down rapidly. I changed the TCU as well to rule that out and the only thing to replace is the ecu. using consult I reset all the setting I could for the tcu, but the only thing I cant do is a clutch point relearn. does any one know if this is required on the 2012 1.2 micra hr12de
