Remote central locking
Stani1029
Hi guys just bought a set so need a wiring diagram and if anyone has previously fitted a set can they pin point where i should connect wires etc. if not ill get there just trying to save a bit of time on the day
Can anyone tell me if my micra's central locking has either positive, negative or positive and negative triggers please
Armando you would be a life saver if you could. I have standard central locking with key yes so just want to be able to do it remotely :)
break the yellow and red signal wire from one of the doors will cause it to unlock, attaching the control box end to ground will lock it again (or the other way around) you need a normally closed relay to break the wire and then put it back together again
Send me your email by PM and i will send you the wiring diagram to connect the alarm box to the stock central locking box...
got a 97 k11 sr loom with alarm+wiring attached,,,,,,dont have the wiring code for the alarm. but we all do for the loom
any good? .alarm has door opening/locking
97 k11 sr loom
this may help someone fitting a alarm or at least they could photocopy it and put it in they window
i need a pdf for this alarm ,aint finding it anywhere so dont know the wiring until the loom wires are copy'd
near ignition,yellow to white green
black to white black
Write your reply...
