When I bought it it needed a little bit of work. So I changed the suspension on all four corners. One of the previous owners thought it was a great idea to cut the springs and let all of them pop out the cups and blow all bar one shock! So with a little modification I got some polo 6n FK automotive coilovers to fit! [ATTACH=full]41781[/ATTACH] I had to re drill the top holes on the front so they would fit on the hub. [ATTACH=full]41783[/ATTACH]I also had to get the top mounts milled down on a lathe so they would fit in the existing cups.
[ATTACH=full]41784[/ATTACH]
The rear also had to be modified! I decided to get my friend to weld me two brackets together as it was the simplest way of doing it.
