I do have both sides but they are not the same pattern. These are off a 4 Door GSX so should fit unless someone knows different..
You can have them for nowt....just postage to pay
NB: There is also a slight bit of damage to the rear of the passenger Card but would not be noticeable when viewed
It's easy to remove them
Firstly get a box to put all the bits in.
1. Unscrew the Door pin and lift out plastic surround underneath it.
2. Remove Door Pull Handle by removing Screw cover plates and unscrew 2 x crosshead screws
3. Remove Door opener Surround by unclipping.
4. Remove window winder by removing the circular clip. Use a piece of strong wire to poke or prise it out then withdraw Handle off the Spline.
NB: Around the edge of the surround are 7 white/grey/black plastic poppers, CAREFULLY lever edges of Door surround with a flat bladed instrument with a V cut into it. You can pull the Door cards off with your hands but beware the poppers are old and may break as well as making the popper holes bigger.
There is also a spring clip which helps to hold the door card in place.
5. The door Card should now be hanging in mid air so the final thing to do is lift up the the inner window strip at the bottom of the window. It should be on fairly tight as it has Grip clips.
Hope that helps
