solarice
K11 Parts (Handling/Engine/Wheels)
Figured id start a new thread to make it easier to understand what ive got sitting about collecting dust...
1. Cam Cover (good cast smooth finish -- needs a good clean though) (£6 +p&p) Pic 1 Pic 2
2. Not for sale at the moment 1.3 Engine Block (does not come with pistons and most toher bits removed so possibly useful if rebuilding another engine, where you can replace the missing bits.) (£? +p&p)
3. 1.3 Head (Includes the inlet gasket, upper tensioner, valves, buckets, shims, side access cover plate and cam bearing caps...it does not come with the upper timing chain sprocket, cam bearing cap bolts, head bolts, access cover bolts, cam cover or cams...i think thats everything
However the missing items can easily be recovered from your existing micra cylinder head and reused.) (£OFFERS+p&p)
4. 1.3 Crankshaft (£? +p&p)
5. Standard Super S (doubt any difference tbh) front brake calipers & bracketry (were fully working when removed -- so should still be good) (£25 the pair +p&p)
6. Stock early type K11 grill started to modify, not been touched since (has a slight crack so needs a repair, not a big deal as youd be finishing the grill anyway
) (£3.00 +p&p) Pic1 Pic2 Pic3
all engine parts taken off a 1995 1.3 with about 85k...seem in canny good condition.
7. Also got a set of four alloy wheels (15" 7j +45 offset) two tyres are done (damn neg camber lol), but i think the other two are ok condition...will come with all the tyres on (195 45 R15)...they can be seen here: ClickMe (£? +p&p)
8. [strike]Standard K11 Airbox (suitable for modifying to increase airflow) (£4 +p&p)[/strike] SOLD
9. [strike]Standard 1.3 Super S (any difference over others??) anti roll bar front. (£? +p&p)[/strike] SOLD
10. [strike]Standard 1.3 Super S (any difference over others?) anti roll bar rear. (£? +p&p)[/strike] SOLD
11. Standard Panhard rod (needs lower bush iirc) (£3 +p&p)
12. Brand new front arm bushes: PIC HERE (£8 the pair +p&p)
13. A Pair of Super S Mudguards (In Primer), they were modified to allow them to be fitted backwards on the sill (can get pic if requested)...it was an attempt to make kind of a mini version of the nismo spats, but were never used and i dont need them anymore because of the arches. They are available if anyone wants to complete fitting them...probably the only set in existance, thats up to you's if thats good or bad thing lol (they cant be returned to normal btw) (£6 posted?) Pic1 Pic2
14. [strike]A set of 4 Super S Mudguards (2 front, 2 rear) was gonna keep these but im never gonna fit them back on, so may aswell let them go (£25 posted?)[/strike] SOLD
15. [strike]Set of four stock 1.3 fuel injectors...cant guarantee spray pattern, but look clean. (£? +p&p)[/strike] SOLD
16. One steering wheel covers...one black/yellow striped (£FREE +p&p)
17. Standard fuel pressure regulator.(£?+p&p)
18. Standard Inlet Manifold (£6+p&p)
19. Standard Single Car Horn (£?+p&p)
20. Drivers and Passenger Wing Mirrors (black plastic, both have slight scratches iirc) and base plate trims (non adustable from inside of car) both are folding iirc (£5 EACH? +p&p)
21. Drivers Door Handle currently in bits and primed (£offers +p&p)
22. Rear boot number plate light thingy (non handled / early version) £offers +p&p)
23. X2 Inner CV Rubber Boots (full type not sticky -- not sure if could be used as outer boots, but probably not) £offers +p&p)
possibly got other bits aswell...but thats all i can remember at the moment...if you want anything give me a shout, and we can discuss what youd like to pay me, same goes if you want pics
all prices are purely a starting point and are no way set in stone...so please haggle...id rather sell something cheaper than keep stuff sitting around doing nowt
cheers.
cheers.
