idle problem
Belly93
to turbo or new lump :/ hmmm
When I pull up at a junction or stop after driving for a while it sounds like the engine is goin to stall then levels out and idles fine and then goes to stall and then picks up again does anyone have anyidea what this could be?
I've just had the same problem with my 1994 Micra L Auto. It would stop at every set of lights when it was warm, juddering, revving, slowing down and spitting and sometimes cutting out completely. Drove me crazy trying to find out what the problem was. Tried everything, then came across this on-line:
http://www.micra.com.au/technical-articles/cg13de-throttle-body-resoldering-guide.php
http://www.micra.com.au/technical-articles/cg13de-throttle-body-resoldering-guide.pdf
I was sceptical it would solve what appeared to be an extremely difficult and unfathomable problem. Guess what? It worked! Amazingly! Afterwards, I drove for two hours up hill and down dale, trying everything to get it to sputter and stop. It is running beautifully, and the responsiveness of the throttle is amazing. It purrs like a cat now, thanks to the guy who posted the re-soldering instructions on-line. Thank you.
Hope this helps someone else.
Write your reply...
