Normal
Yeah i would recommend changing the wishbone like most other cars since bushes are a ##### to remove and worthwhile doing the whole lot.The balljoint is attached to the hub so this will have to come off, may require balljoint separater or a chisel. once that's off the other two end needs to be undone. Be careful though you done pull the drive shaft out since the hub will be able to move freely once that's off. Then just do the reverse to put the new one on.
