Whats best to use to clean it?I'd give the throttle body a good clean out and those sensors
I'd say its the idle air control valve. Give it a cleanup and it should be happyCheers will give it a go just took it out for a run and the only time it cuts out is when you stop so al give it a go
Keep us postedOk will give it a go thanks for the help![]()
Try giving you throttle body a good clean out as aboveThis is whats happening to mine cutting out when stopping I was told to adjust the idle which has been done but its still doing it![]()
Not really. Redex will only clean injectors outWud a tank of redex'd fuel n a good afternoon drive nt do it?
Try cataclean, cleans out most of the system I found, really good - £7 on Amazon. If not, I think you need to clean your throttle body as suggested. Plenty of threads on here to check with.Wud a tank of redex'd fuel n a good afternoon drive nt do it?
