General Tune Up
I bought a K10 (1986) in November last year for my son to learn to drive in. When I got the car, it was running really roughly, but there were no ratlles and no smoke, it changed gear OK and nothing clonked in the suspension. For £100 it seemed OK, but clearly, the engine needed tuning.
It had had a new rotor arm, dizzy cap and leads, but within a week it stopped starting. New points, condenser, coil and vacuum leaks sorted, Bob's yer uncle it's running.
I've run cars of this vintage before, but was suprised to find from Haynes that:
Plug gap is 0.8 - 0.9mm - not 0.7- 0.8mm I'm used to
Points gap is 0.45 - 0.55mm - not 0.3 - 0.4mm I'm used to
Timing is 2° ATDC not X°BTDC as I'm used to.
The previous owner had set it to the "used to" settings, so using the correct settings made a big difference and I had it running much better.
It jerked a bit on acceleration, some kind of misfire I guessed. This was improved by adjusting the tappets and adjusting the fuel level in the carb - I learned that from the master Sammo (Y) - This is an incredibly easy thing to check ( a rag and a torch - job done), mine was low and I reset it by bending the tab on the float - a one hour job tops). However, the misfire never went away completely.
One month later, Eastbourne to Bridgwater and back in one day - 400 miles at 55 mpg, nice:D - still misfiring slightly when trying to accelerate. New plugs with the correct gap produced an improvement but still no cigar.
So what is amiss now?
Its done 120K on as far as I can tell, the original distributor. So I stripped the dizzy down to the mechanical advance/retard weights. This is not a difficult job and first time round it took about an hour. I cleaned everything in petrol, removing some very old looking grease, lubed it up with LHM grease and reassembled "in the reverse order". I had put the cam on for the points 180° out of phase, so it didn't fire at all. Once that was sorted, it fired up straight away.
Plugs and timing checked, mixture set with Colourtune, and it really is purring like a kitten. It pulls smoothly from cold up hill. Once warm, I can accelerate from 15 - 20 mph in top gear - sad I know - and it never hesitates or misfires at all.
I'm sorry for the long tale, but my points were that:
1. Plugs, points and timing are slightly different to what I had experienced before and had I not bought a Haynes manual, I would still be setting them wrong
2. Check the fuel level in the float bowl! Rag, torch - piece of cake
3. After 120K, things like the weights in the distributor need cleaning and re-greasing. They never turn up in a maintenance schedule but after 20 years I guess they're going to need an overhaul.
4. Read the forum - the infos out there
I hope you find this as useful as I have reading the stuff on this forum
Tricky
Nice one tricky!!
Cool write up! And thanks for the Qdos...LOL
I had a certain amount of hesitation on acceleration and an awfully uneven idle when hot..(the timing was a pain to read because of this)
My float height was marginally low and the semi-auto-choke was warn and was difficult to set in the mornings......
I changed a whole host of electrix bits from a very low mileage K10 to try to fix these problems but for me none of them worked....(electronic dizzy, leads, coil,condensers)
As part of another project; I had the low mileage K10 inlet on the bench...when I had finished modding this a swapped it over with my old (107k miles) one and ALL my running problems dissapeared into thin air!! ( now I have smooth idle when warm, stable timing readings with the strobe, beautifully working semi-autochoke in the mornings)
Lovely!
So although I’ve not pinpointed it has to have been either somewhere on the carb or the vacuum lines that was causing my warm uneven idle and timing jitter
I've seen the colourtune on the shelf but have been unsure about how easy and effective it will be to use....how did you find its practicalness and effectiveness?
Was it easy to distinguish the variation in colours whith small adjustments if mixture???
Sammo
I find the Colourtune very easy to use. You take out a spark plug, preferably on the same side as the idle mixture adjustment and replace it with the glass centred Colourtune one, fit over a black tube to help you see the mixture when the ambient light is bright and hook up the spark plug lead. Richen the mixture and it goes clearly orange, then weaken it until it just turns blue and this is supposed to be the optimum mixture. I generally weaken it a little bit more to be on the safe side.
The only problem with it is if your engine burns oil as this will burn with an orange flame like a rich mixture regardless of the actual setting.
It is obviously not as accurate as an exhaust gas analyser, but a good place to start
got my mint condition hard back haynes manual off ebay for the massivly price of £5 inc p&p (£3 was p&p!) :B
Write your reply...
