fuel is only priming sometimes
I've tried looking online if anyone has had a similar problem to what i have and all i can find is a post for a Honda Delsol, my problem being that fuel will only be primed sometimes. If i go to start my car, and put the key in the ignition and turn to the on position, most of the time will not hear the fuel pump priming, only rarely will it start first time, all the other times i have to wait until i can hear it priming to start the engine. I've replaced injectors, MAF, full service done, and checked fuses. I'm yet to check fuel pump relay and the wiring for the fuel pump relay as i cannot find anywhere on the internet where it is for a second facelift. It seems to be a problem that is not common, any help is appreciated. My car is a 2001 K11 998cc.
