First time poster, need advice on replacement horn
Hi all, I wonder if you can help a newbie with a question on a K12. I have a 2003 1.5 DCI and the horn has packed up on it. I have tried the fuse, checked the relay which is clicking when pressed and I have come to the conclusion that it is the horn itself is gone.
I was looking around at this horns you see on eBay or local motor factors that are around £5 - £10. I know these horns come with spade connectors and I haven't looked at the horn yet, but I was wondering if the Micra uses spade connectors to connect to the horn or a plug type end to connect.
As I was wondering whether to get a 2nd one from a scrappy or a new one. Any help is appreciated. Thanks.
Anthony
Write your reply...
