Engine CFM
you,re the compressor engineer lol :p, and the pressure depends on the size of the orifice surely ?
a straight through exh will be pretty low and pulsed eh, but fit a T15 turbine and it will hit 100 psi maybe ?
Haha, true, tge biggest machines I deal with are about 200 CFM, but that is a 50 hp electric motor at 8 bar, so does this equate to a 50 hp engine?
1L engine will exhale 1L of air per 2 revs eh (if the VE is 100%)
times that by the rpm
then divide it by how many L in 1 Cu ft :)
Only reason I'm asking coz I wondered of I could conduct some bench tests with an air compressor to see how good the turbo actually is. ( I get bored quickly when I've run out off things to do!)
There's 28,316 litres In a cubic foot
So 1L x 6000 rpm divided by 28.316 = 211.9
That right? I'm confusing myself now
like a vortech supercharger eh neil, get a mofo 12v motor to spin a TD06 @ 100k :cool:
The idea was, find the output CFM of my engine, then attach it to airline off compressor matching that, then measure the output off the turbo :)
Jus coz lol
