Replaced my drivers side door lock mechanism last week and all good with that, but having put everything back together I now have a problem with my electric window being very slightly misaligned, It to be not quite closing up to the weather seal and slightly over too far so that the top corner is hitting the top corner of the door seal.
I didn't loosen any of the window guide rails or anything else to do with the window, I did remove the two black polystyrene blocks from within the door panel and didn't replace them because the plastic fittings wouldn't hold them in place, could this have affected the window alignment? Any help would be greatly appreciated, although it's not a major issue I think that the rain will get in now, Thanks in advance
