Does anyone know
ollyc98
if I can adapt some bike headers like these:
To fit the k10, is it as simple as welding a flange to the end (if measurements are correct)?
yeah a flange can be welded on no problem, but looks it wont either go down far enough to get under the sump, your want to match it up first!
Does look like it will give a ok top end but your lose a lot of bottom torque and due to the design of the inlet manifold wont gain much in the way of top
Yeah it's just an idea I'm playing with, obviously I'd have to go through a load of different headers to find the right lengths, I also want to go with sidepipes.
It'l probably be alot easier and cheaper to get a new one made up to your specification
Yeah, I was planning on doing the work myself to lower the cost, though the inlet manifold will probably be done first.
