Coolant Pipes Temperature Difference K13
Hi all,
Just joined the forum this evening, I wonder if anyone can help?
I have a Micra that was over heating, I've done a coolant flush, fitted a new thermostat, filled with new coolant. Does anyone know what (approx) temperature the top & Bottom radiator hoses should be? I'm assuming there should be a difference? Also the two rear (heater matrix?) hoses? TIA Currently the car is SORNed so haven't had the opportunity to go for a road test
OH No Radio Code?..... Try this: Press & hold "4" and while holding press ON button TWICE, It unlocks the radio but you will need to repeat each time you use the car.
