breaks locking
johnsams
MICRAPOWER!
the breaks seem to lock quite easily rather than slowing down quickly it just skids everywhere, anyway to stop this and improve the handling?
thanks
john
Do you have ABS?
If so it might need looking at.
If that's ok then a little less boot would suffice :)
yeah, i should probably lay off the heavy boot...
no ABS though its a 94.
i think maybe some good tyres ( i'm currently rocking cheapies and all 4 are of different brands:/) and bigger/wider alloys?
i'm only on 14s at the moment...
thanks for the help guys!
frank
im not sure, but it makes it steer to the left slightly when it does lock up... nothing too extreme though.only happened on a few occasions though, could just be my rough driving.
john
if its the rears locking up, it could be a load apportioning valve problem
i always test mine by hitting the brakes on a loose surface and checking the length of the 4 skidmarks
My K11 used to do it all the time! Put a set of decent tyres on it and it was fine! Also cleaned the brakes up a bit coz they were binding on slightly!
Write your reply...
