different ecu and wire pinouts naz, but same processis this the same for k11 1.4 frank
modern ecu "self-learn" is a cunning system thenThat was the example I was referring to. It resulted in that case with a melted piston as the Motronic was essentially trying to undo the changes that the e-manage was trying to implement via fueling and ignition.
