Aluminium Catch/Header Etc Tank
solarice
Suitable for any car.
Had this sitting around and its taking up space, so figured id see if anyone on here can make use of it.
Its about 6" long x 4" wide and 2 x 10mm od pipes...has a bracket welded to it, this hasnt been drilled yet so its ready for whatever youve got planned.
£35 posted? (but as always open to offers)
Cheers.
Just did a quick search (cos i can never remember how to work out volume)...and if ive worked it out properly...it should hold about 1.23 Litres.
But id double check yourself just to make sure (if its important) :)
Edit:
Just did a double check on the measurements and its closer to 150mm x 108mm (a little shorter and wider than above) ...which is about 1.37 Litres...though it'll be a little less as they're outside measurements.
again id double check these though :)
This is still available...will do it for £30 posted...if anyones interested :)
EDIT:
Potentially Sold...pending payment.
