Reply to thread
are the plugs the right standard heat grade and gapped correctly? if by NGK it should be bkr5e-11 and gapped at 1.1mm
remove the dizzy cap (prefer to mark the dizzys position, remove the dizzy off the head then unscrew the cap) n wirebrush the white oxide off the 4 contacts.
get the cylinder compression checked they're equal.
