ok. well.,.
were to start
1) drivers side mounting needs to be altered
2) need to invert and fabricate aggsisting gearbox mount to fit k10 mounting (so passenger mount needs sorting)
3) the under support bar needs to ba added (k10 doesnt have one) this would require bolting and sheet metal a panel so the bopolts didnt pull straight through the floor plan!
4) you would require an electric pump (powerfull enough to mount sumwere near the tank to pull from th tank but also pump through to the engine (landrover style)
5) you would require to run wiring from all the ionjectors systems (k10=carb, k11 = injectors) so in theory would be better to fit the WHOLE k11 wirringin loom and then splicw connectors for lights etc!
6) driveshafts need altering. (gearnbox ends are different)
7) you need to alter the drive system to a k11 (use my brake upgrade
8) you may also requirte to dish the drivers side leg (sits to high, and power steering pulley clashes)
9) also need to deviate away from the brake servo (alloy, easily brakeable) as it will sit to close, any jump in the engine will snapo this (casuing brake failure)
10 ) NOBODY has done this (so u will be the one to experiance all the problem, other than the ones i mentioned)
good luck
