1.3 engine into 1.0 k10, advice please.
I need more go in the old micra so I'm considering the 1.3 out of the k11, does anyone have any links to a build or advice on the swap, would I just need the engine or would I be better off buying a donor car, Ive had a search about but haven't found a definitive answer to any problems encountered.
Thanks.
Essentially just need to make a new driverside mount.
Then use a preface lift cg10 flywheel and clutch.....that bolts straight onto your ma10 gearbox
Then it's up to you if you go carbs or injection
Write your reply...
