Normal
the box you have should fit. you'll need the rear box mount from the 1.3, and also the gear selector rod. it is possible to fit a mechanical speedo drive, but you'd need the speedo drive from a 1.3 pre '98 as they are larger than the pre '98 1.0. nats isn't an issue when it comes to either the engine or box.
